[Solved] TSMuxer fails to start
DetectiveKenobi
Re: TSMuxer fails to start
Post by DetectiveKenobi »
I downloaded the latest nighty build and tried both Tsmuxer and Tsmuxer-New and still same issue. :cry:
Dang. Welp. Thanks for the help. Looks like it's just an OSX issue.
On my machine I had to set executable permissions and I thought that would cross over into the build but maybe it didn't. Can you try setting the permissions of the tsMuxeR-new file? Via the macOS terminal it should be like:
sudo chmod 755 tsMuxeR-new
DetectiveKenobi
Tried it from within the UMS folder. Didn't work.
I then went to the download of the latest tsmuxer build and ran it and then copied it over and same thing.
I can't reproduce this anymore on my machine but maybe that's some kind of permissions caching thing. I'm trying to get access to another macbook to test a fresh install on.
What happens when you run that chmod command above? Does the icon change? For me it changed the icon of the tsmuxer files to black like my screenshot, while before they were a different icon
Screen Shot 2021-11-26 at 12.16.56 PM.png (56.51 KiB) Viewed 14298 times
I think I have a fix, please test it https://www.universalmediaserver.com/up ... xerfix.dmg
DetectiveKenobi
I installed it and it still the same thing. I did update to OSX Monterrey but still same thing. Gonna try a fresh install of UMS tho.
DetectiveKenobi
Same thing on Version 14.1
Very strange, I even tested it on another machine to make sure. I'll have to give it another think and try
DetectiveKenobi
Here are the debug files.
ums_dbg_2021-12-28-22-05.zip
(29.14 KiB) Downloaded 2439 times
Thanks. I haven't forgotten about this, will get to another attempt soon
