[Solved] TSMuxer fails to start
Re: TSMuxer fails to start
In your logs I can see:
TRACE 2021-12-28 22:04:27.499 [main] net.pms.io.SimpleProcessWrapper Executing "/Applications/Universal Media Server.app/Contents/Resources/osx/tsMuxeR -v"
TRACE 2021-12-28 22:04:27.510 [SPW "tsMuxeR" consumer] net.pms.io.ListProcessWrapperConsumer Process output: dyld[72978]: Library not loaded: /usr/local/opt/freetype/lib/libfreetype.6.dylib
TRACE 2021-12-28 22:04:27.511 [SPW "tsMuxeR" consumer] net.pms.io.ListProcessWrapperConsumer Process output:   Referenced from: /Applications/Universal Media Server.app/Contents/Resources/osx/tsMuxeR
TRACE 2021-12-28 22:04:27.511 [SPW "tsMuxeR" consumer] net.pms.io.ListProcessWrapperConsumer Process output:   Reason: tried: '/usr/local/opt/freetype/lib/libfreetype.6.dylib' (no such file), '/usr/local/lib/libfreetype.6.dylib' (no such file), '/usr/lib/libfreetype.6.dylib' (no such file)
and I can see that when I run otool, that confirms it is depending on libfreetype:
otool -L tsmuxer
tsmuxer:
	/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
	/usr/local/opt/freetype/lib/libfreetype.6.dylib (compatibility version 25.0.0, current version 25.0.0)
	/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 904.4.0)
	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1292.60.1)
which is a regression of the bug I reported to the tsMuxeR developer at https://github.com/justdan96/tsMuxer/issues/443
I have left a new comment about it and will keep following up
Edit: I noticed there is a new active maintainer now too so I opened a new issue to make sure it gets seen https://github.com/justdan96/tsMuxer/issues/539
It looks like they fixed it, and I confirmed it again with otool. Here's a build for you https://www.universalmediaserver.com/up ... Kenobi.dmg
DetectiveKenobi
Post by DetectiveKenobi »
Seems like it works. but in the menu it says that transcoding engine tsmuxer is disabled?
Screen Shot 2022-01-21 at 5.07.02 PM.png (119.26 KiB) Viewed 6635 times
Will it enable if you select it and press the green button on the bottom next to the arrows?
DetectiveKenobi
Acted kinda wonky but it seems to be working now! Thanks.
Yay!
