[Solved] Movie Cover Art on UMS is lacking
Re: Movie Cover Art on UMS is lacking
@Subjunk it seems like the problem in API.
Thanks for the feedback. And by the way I don't mind screenshots of other programs, it's good to see the comparisons
We have merged the changes that have been made so far to make UMS recognise that filename format, and next I will look into why the metadata isn't showing up. I'll send you another test build when that's ready, and thanks for your kind words about UMS This is a fairly new area for us that we are working hard on, both in the downloadable client and on our web servers.
A fix is live on the API server for Beasts.of.No.Nation.2015 and The.Conjuring.The.Devil.made.me.do.it.2021
For Birds.Of.Prey.And.The.Fantabulous.Emancipation.Of.One.Harley.Quinn.(2020) it's not working because IMDb has it as just "Birds of Prey", so if you rename it to that it should work
Also the failed results are cached on your computer so you'll need to clear that somehow. It will automatically happen when you rename birds of prey, but for the other two files you could rename them in some way, or just clear or delete your cache. The easiest way to do that is to close UMS and delete your database folder. I'm working on a fix right now to make the "Reset the Media Library" button clear the IMDb data.
Thanks Subjunk, yes this did the trick. I also noticed I dont need a parenthesis around the year ? was this a change made on the server? im just going based off movies i transfer in that are not named this way. Subsequently i removed the parenthesis from Birds.of.Prey.2020 and it worked, prior to it did not
Yes we made the fixes to the client and server, glad it worked! Please let us know if you notice any other failures, I'll mark this as solved
Re: [Solved] Movie Cover Art on UMS is lacking
Hi Subjunk, yes one last and most recent problem, not sure what happened but my cover art images are suddenly not cached or downloading ? not sure, if i click on the movie I can see the cover art but not from my movies page? any ideas?
- Screenshot from 2021-06-13 07-43-51.png (620.25 KiB) Viewed 4868 times
I noticed that too locally and I'm not sure why yet. I'll look into it and post back when I have something
Have you noticed this happening again? I can't reproduce it
Never again, I even updated to 10.7.0. This is fully resolved thank you Subjunk
Thanks for your help!
