[Solved] Bravia X detected as Bravia W
Re: Bravia X detected as Bravia W
I think it would work to put the literal friendlyName in the config so it would be like:
UpnpDetailsSearch = friendlyName=KD-70X690E
and then remove the UserAgent lines
That would do it but shame it is a custom conf that will only work for that model TV and not being able to update the X conf for other TVs in that series.
Sony-BraviaX-mod.conf
(2.48 KiB) Downloaded 1806 times
Yes it seems that Sony has a bug with that TV and there's not much we can do about it :( Hopefully they will fix it with a new firmware update
ivantheviking
Post by ivantheviking »
That .conf still didn't work :shock:
This TV is going to be the death of me. It works fine if I disable all renderers :lol:
In any case, it still looks like UMS still doesn't classify it properly. Oddly enough, this started a few months ago with the last firmware update pushed in by Sony, this makes sense.
Thanks so much for the tenacity.
debuginfo.gz
(67.41 KiB) Downloaded 1947 times
Very strange. I had one thought that you may be copying the conf to the wrong place but it does appear in the list of renderer confs at the start of the log so thats not it.
Try this one where I've simplified it even further and given it a much higher priority.
UpnpDetailsSearch = 70X690E
LoadingPriority = 5
If this does not work I'm out of ideas :(
(2.47 KiB) Downloaded 1871 times
ivantheviking
Winner winner!
That one works mint, UMS now sees the TV correctly.
See attached log, it appears that the exact name and higher priority made the trick happen properly.
Thank you. I'm not sure how you would include this in future releases though.
debug.log.gz
(55.51 KiB) Downloaded 1919 times
Great :D
I think this problem is unique to your TV so there is no point including it in future versions.
Since this is a new conf file it will not be overridden when a new version of UMS is installed.
ivantheviking
Re: [Solved] Bravia X detected as Bravia W
Sweet!
Thanks a bunch, I will keep this file handy, and now anyone else who has the bad luck to own this TV has a fix as well.
Hopefully Sony fixes the firmware someday, but I'm not holding my breath.
-Ivan
