[Solved] MS Edge Causes Process CPU/Memory Spikes
I'm running 10.10.1 after upgrading from 9.something and it doing the same thing. The OpenJDK process spikes at the same time as the Windows DNS service.
This happens every ~2 minutes.
18:35:43 DEBUG Sending ALIVE...
18:36:14 DEBUG Sending ALIVE...
18:36:45 DEBUG Sending ALIVE...
18:37:15 DEBUG Sending ALIVE...
18:37:21 TRACE Received a M-SEARCH from [192.168.10.98:59227]: M-SEARCH * HTTP/1.1
HOST: 239.255.255.250:1900
MAN: "ssdp:discover"
MX: 1
ST: urn:dial-multiscreen-org:service:dial:1
USER-AGENT: Microsoft Edge/93.0.961.38 Windows
- Untitled.png (13.17 KiB) Viewed 3397 times
[Solved] Re: MS Edge Causes Process CPU/Memory Spikes
Create and run a .reg file with this content:
If you want to disable it in Chrome use/include:
Basically the browsers do a network discovery scan for cast devices every X seconds and it causes a spike. Do note that this key disables casting from the browser. If you want to continue to cast from your browser I suggest only disabling it for one browser and using the other to cast from. In Chrome make sure "Continue running background apps when Google Chrome is closed" is off too in case it matters for the media routing.
Please note I am not affiliated with UMS nor am I giving official support for Microsoft so any changes you make to your system are your own choice and I am not responsible for any frowning, frustration, keyboard smashing, or problems you may have as a result. If you are happy with results I will accept credit though
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge]
"EnableMediaRouter"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Google\Chrome]
