Don't want local media folders displayed
JDN165
Post by JDN165 »
I've created virtual folders using the VirtualFolders.conf file and this works fine.
There's no need for me to add physical folders in the Shared Content tab, so I leave "Shared Folders" in this tab empty.
However, for some reason UMS now adds my Windows local media folders (Music, Video, Pictures) to the Shared Folders, which I do not want. I just want to navigate through my virtual folders and don't need (and don't want) these local folders. When I delete these 3 unwanted folders, they are added again when UMS is restarted.
How can I prevent UMS adding these folders?
JDN165
Re: Don't want local media folders displayed
Post by JDN165 »
Clearly a tough question.
What I ask is not possible?
Of should I perhaps ask this question in the Help and Support section?
I'm not sure it is supposed to do that.
I think on a new install those are added as default for new users if no folders are set, but maybe they is a flaw in the logic so if you delete those then UMS thinks it is a new install and tries to be helpful by adding them again.
I'm sure this was not the behaviour on older versions.
I have noticed something similar with the web content folder, If I delete everything it will be repopulated when UMS is restarted. I have to leave at least one item.
I have created an issue on GitHub for the devs to look in to it
