Transcode folder still showing - despite Transcoding being disabled
shoe
Post by shoe »
for testing purposes I added
disable_transcoding = true
to UMS.conf but the "TRANSCODE" folders are still showing up.
I know there is an show_media_library_folder = false option which I didn't use!
But my question is, is Transcoding really deactivated? I used log_level = ALL and I can't find anything. Shouldn't it note that Transcoding is deactivated? It also loads all the transcoding engines in the Log.
Can somebody please clarify?
Thanks!
Re: Transcode folder still showing - despite Transcoding being disabled
The disable_transcoding option disables automatic transcoding if the video is not supported by the renderer defined in the renderer conf
The #--TRANSCODE--# folder is separate virtual folder that allows you to force transcode using various engines for testing and the ability to choose the audio/subs to be used.
If you do not want to see this folder you can turn it off by unchecking the Show the #--TRANSCODE--# folder option in the navigation tab.
You can also disable the transcoding engines individually in the transcoding settings tab.
