[Solved] UMS is damaged and cant be opened
Re: UMS is damaged and cant be opened
endymion you genius!
sudo xattr -cr /Applications/Universal\ Media\ Server.app worked!
Thank you very much. And it sees PS4 ok....
I am now back to my original problem which led me to delete and reinstall UMS......My files are on an external drive. So when selecting folders to share within UMS, I navigate --HD/volumes/....
But once selected volumes there is nothing visible and the window seems distorted. Please see the attache screenshot. Does yours appear like this? So I cant any deeper than selcting my volume 'Backupemp'. Before Monterey I could navigate further into the volume.
MAny thnanks for your help...
- Screenshot 2021-11-02 at 03.55.48.png (335.67 KiB) Viewed 3087 times
I suggested setting the attributes early on, and from what I understood you claimed to have already tried it and that it didn't work.beard runner wrote: ↑Tue Nov 02, 2021 3:57 pm sudo xattr -cr /Applications/Universal\ Media\ Server.app worked!
When I go to my Volumes folder, a security alert appears.
I hit OK and after some spinup delay my external drives appeared.
If you don't see that, you may have previously accidentally clicked Don't Allow.
You can go to System Preferences --> Security & Privacy --> Privacy --> Files and Folders
Scroll to find Universal Media Server and if it displays Removable Volumes unchecked. Check it.
There has been some really great help in this topic, thanks everyone involved!
I just wanted to add that Apple has a help page about this which includes a Monterey section, here's what they say:
https://support.apple.com/en-gb/guide/m ... h40616/mac
Hopefully Apple will make better decisions around supporting open source apps in the future. I don't see any indication of that but I can only be hopeful.
This allowed me to run 11.11.11.1-pre 10.15 on High Sierra (please don't judge).endymion wrote: ↑Tue Nov 02, 2021 11:40 am Also, if you're still seeing notes that the app is damaged, try opening the terminal and typing:
or
sudo xattr -cr (and then drag the app into the terminal window to complete the path if stored elsewhere)
Then enter your password when asked and try opening the app again.
Thank you!
