Version 10.13.0 released
Re: Version 10.13.0 released
OK it is good that it is repeatable as it will help track the problem down, but I think this will have to be something the devs will have to investigate as I have no idea on what is causing it. :(
It would be great if you could see if this is a new problem, can you install some old versions to check?
Sometimes older versions won't be compatible with current settings so it can be good to make a backup of your settings in ProgramData/UMS and then do a Clean Install
sdabrams3
Post by sdabrams3 »
SubJunk wrote: Sun Nov 28, 2021 12:47 pm It would be great if you could see if this is a new problem, can you install some old versions to check?
Subjunk/Mik,
Ok so completely uninstalled 10.13 and also deleted the C:/ProgramData/UMS/database so that it was recreated during install
Installed 10.10.0 and looked at my L:/MN movies and all the tumbnails were screwed up and not matching up the filenames
Added D:/Movies D and saw the very same tumbnails from the L:/MN attached to the movies located in the D:/Movies D directory (very strange)
Attached the log files
BTW was using Windows 10 when all of this started way back and using Windows 11 has not changed any of the results.
Scott
ums_dbg_2021-11-29-19-52.zip
(343.21 KiB) Downloaded 470 times
sdabrams3
Post by sdabrams3 »
All,
Has anyone made progress with this bug?
Scott
