Merge Subfolders within Virtual Folders
iCEQB
Post by iCEQB »
I didn't want to resurrect a dead thread from 2013 but the OP here is suggesting what I'm after as well:
viewtopic.php?t=1475
It would be great if this feature could be implemented, as I have like 4-5 drives, with the same folder structure, which go like this:
Drive C:
|-- Movies
        |-- 720p
        |      |- Multiple Movie Subfolders
        |-- 1080p
 Drive D:
|-- Movies
        |-- 720p
        |-- 1080p
 Drive E:
|-- Movies
        |-- 720p
        |-- 1080p
When I setup a Virtual Folder called "Movies" with all the drives like this...:
virtual_folders =Movies|C:\\Movies,D:\\Movies,E:\\Movies
...the Virtual Folder shows up like this on my TV:
Movies
|- 720p
|- 720p
|- 720p
|- 1080p
|- 1080p
|- 1080p
I'm no coder but the OP in the linked thread above seems to have found the cause(?)/solution to this.
So the addition of a toggle in the config, to signal the server to merge the same sub directories across multiple sources would be great!
I hope this is not a big request :oops:
Re: Merge Subfolders within Virtual Folders
Just tested it out using the virtualfolders.conf but the sub directories are not merged too. Best way I can see round this is to set up virtual folders for each of the resolutions.
You need to set up a VirtualFolders.conf in C:\ProgramData\UMS and edit UMS.conf to set
virtual_folders_file = VirtualFolders.conf
Set up your VirtualFolders.conf like this, note the double slashes (\\) instead of singles.
		"name":"Movies 480p",
		"addToMediaLibrary":"true",
		"files":"C:\\Movies\480p","D:\\Movies\\480p","E:\\Movies\\480p"]
		"name":"Movies 720p",
		"files":["C:\\Movies\720p","D:\\Movies\\720p","E:\\Movies\\720p"]
		"name":"Movies 1080p",
		"files":"C:\\Movies\1080p","D:\\Movies\\1080p","E:\\Movies\\1080p"]
so it will appear like
Movies 480p
Movies 720p
Movies 1080p
I know it is not quite what you want but is close enough. Maybe you can make a request to add that feature on GitHub by opening an issue.
I'm no coder either but it should be easy enough to merge subfolders if they are named the same. If the code handling virtual folders has not changed then that solution posted in the other topic could be added.
notesmedia
Post by notesmedia »
thank you for this, been trying to do it too lol
