ERROR There is no inputstream to return
largan
Post by largan »
I am using UMS 11.6.0 on Linux Mint, and I am getting these errors
ERROR External input stream instance is null... stopping process
ERROR There is no inputstream to return for The Valet (2022) {English subtitles}
I have tried searching for similar issues in the forum, but none of the solutions/hints helped.
This is the version of ffmpeg I am using
ffmpeg version 4.2.7-0ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil      56. 31.100 / 56. 31.100
libavcodec     58. 54.100 / 58. 54.100
libavformat    58. 29.100 / 58. 29.100
libavdevice    58.  8.100 / 58.  8.100
libavfilter     7. 57.100 /  7. 57.100
libavresample   4.  0.  0 /  4.  0.  0
libswscale      5.  5.100 /  5.  5.100
libswresample   3.  5.100 /  3.  5.100
libpostproc    55.  5.100 / 55.  5.100
I also have MEncoder installed.
I have tried using TrueType font
Also, while loading UMS I see this error
ERROR Error in RealFile.resolve: Cannot invoke "com.drew.imaging.png.PngColorType.getNumericValue()" because "this.parsedInfo.colorType" is null
Here are also the settings screenshots
If I try with MEncoder, the subtitles are show but the video is not smooth
If I try with ffmpeg then I am getting the error
I am attaching the log too
Any help will be very much appreciated.
ums_dbg_2022-12-13-00-07.zip
(385.81 KiB) Downloaded 48 times
Re: ERROR There is no inputstream to return
I missed this and only come across it while searching for a similar problem that was caused by using the incorrect version of FFmpeg.
More info here if you are still around.
