[Solved] Web Interface not available since update to 13.1.0
MTOakey
Contact:
Re: Web Interface not available since update to 13.1.0
Post by MTOakey »
mik_s wrote: Sat Feb 04, 2023 9:39 am ... Sorry but you did not post about this problem.
viewtopic.php?t=15595
Greetings once again ... as you will see, I did indeed post about this problem, however, I did NOT really think it was an issue with UMS since UMS has worked almost flawlessly since v6.
And, I have been using UMS to "serve" externally since v6 without error, mostly. All one needs is a Static IP from their ISP, or a service which will automatically find, and translate that external IP so it can pass through to your Router, which you "Forward the Port" necessary and it all works, flawlessly and blindingly fast... until 13.
So, now, my follow-up question still stands ... Since there are so many, and, across the board bugs/fails in this 13.1 - when will 13.2 be available to the general public - since several of you "think" or "believe" all these hiccups have been addressed and/or repaired in 13.2 ??? ...
“A truth’s initial commotion
Yes there is no mention of the problem accessing web settings related to the issue in this thread on your previous post. I have read it 3 times now.
Again I don't know about running UMS externally. you have your occupation listed as Network Admin so you know more than me. Sorry I can't help with that.
I don't know when the release will be. This is all I know at the moment.
plotzkella
Post by plotzkella »
The problem is fixed with version 13.2.0, thread can be closed.
MTOakey
Contact:
Re: [Solved] Web Interface not available since update to 13.1.0
Post by MTOakey »
The issue NOW is - 13.2 is not available yet, to me.
plotzkella wrote: Wed Feb 08, 2023 8:07 pm The problem is fixed with version 13.2.0, thread can be closed.
Thanks for confirming it works
@MTOakey
It has been available on the front page for a day or so just after it was released on GitHub.
