Java Runtime Environment
ValleyCat05
Post by ValleyCat05 »
I've tried multiple times now to install UMS on my new Mac mini and I can't open it. When I try, it gives me an error message reading "Unable to load Java Runtime Environment" and nothing else (see attached). I've tried installing, uninstalling, and reinstalling the latest version of Java; reinstalling UMS; restarting everything; even updating my computer, but nothing changes. I have no idea what's going wrong or how to fix it.
My computer is running macOS Ventura 13.3.1
Thanks!
Screenshot 2023-04-28 at 7.02.24 PM.png (19.02 KiB) Viewed 4610 times
Re: Java Runtime Environment
I don't know anything about Macs so probably won't be of much help here. If there were some logs I could probably see what is happening but if JRE is not running then there will be no logs.
JRE should be installed with UMS. Maybe its installation is failing or a version of it is already on your system.
I just did quick google and found this which is similar and the same fix may work.
I also found this post from last year where the solution was to delete UMS and install from the .dmg package.
