Version 3.4.0 is released
General:
This release adds encoded audio passthrough, improves 3D support, adds support for the Google VP9 codec, improves support for most popular codecs, improves speed and more!
Changes since 3.3.0:
  • General:
    • Added "Encoded Audio Passthrough" option for DTS and AC-3 audio
    • Added support for 3D MKV files (mk3d)
    • Made font cache creation over 50% faster on Windows
    • Font cache creation is done in the background
    • Expanded filename prettifying
    • Clicking "Check for updates" tells you when there are no updates
    • Image thumbnails are generated faster
    • Fixed FLAC support on some players
    • Removed broken entry from WEB.conf
    • Minor English language improvements
  • Renderers:
    • Improved support for the Vizio renderer
  • External Components:
    • Updated Commons Codec to 1.9
    • Updated Commons Configuration to 1.10
    • Updated FFmpeg to builds from 2014-01-05+, which:
      • Adds support for reading and setting stereoscopic (3D) metadata for MPEG-2, H.264 and H.265 streams
      • Improves AV sync, especially when outputting MPEG-TS
      • Improves support for the following audio codecs: AC-3, DTS
      • Improves support for the following video codecs: VP9, H.264, H.265
      • Improves AviSynth support
      • Improves Matroska support
    • Updated InterFrame to 2.5.1, which:
      • Improves quality
      • Improves GPU support
      • Fixes bugs
    • Updated JGoodies Forms to 1.7.2
    • Updated JGoodies Looks to 2.5.3
    • Updated JNA to 4.0.0, which:
      • Fixes bugs
    • Updated MPlayer/MEncoder for Windows to SB55, which:
      • Adds Google VP9 support
      • Improves support for some DVDs
      • Speed improvements
      • Fixes memory leaks
      • Fixes a fontconfig bug
      • Improves support for the following containers: AVI, Matroska, MPEG-TS
      • Improves support for the following video codecs: H.264, H.265, MPEG-1, MPEG-2, VC-1, VP8
      • Improves support for the following audio codecs: AAC, AC-3
      • Improves detection of 60FPS
    • Updated MediaInfo for Windows to 0.7.67, which:
      • Fixes bugs
    • Updated Netty to 3.9.0, which:
      • Improves speed
      • Fixes bugs
    • Updated Thumbnailator to 0.4.7
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
Wolfgan
Re: Version 3.4.0 is released
Post by Wolfgan »
Thx for the release. Will install and test it! I noticed that tsMuxer lately updated to v2.6.12 but UMS seems distributing v2.2.3, w/o including some improvements and fixes in between (http://www.digital-digest.com/software/ ... ry.html#61). Any reason for that?
Thanks again, Wolf
awschmidt
Post by awschmidt »
thanks for the new release, but UMS 3.4.0 can't work with movieinfo anymore.
Error:
02-06 20:07:47 Exception in thread "main" java.lang.NoSuchFieldError: EMPTY_BORDER
02-06 20:07:47 at net.pms.movieinfo.MovieInfo.config(MovieInfo.java:99)
02-06 20:07:47 at net.pms.newgui.PluginTab.appendPlugin(PluginTab.java:420)
02-06 20:07:47 at net.pms.newgui.PluginTab.addPlugins(PluginTab.java:413)
02-06 20:07:47 at net.pms.newgui.LooksFrame.serverReady(LooksFrame.java:568)
02-06 20:07:47 at net.pms.PMS.init(PMS.java:695)
02-06 20:07:47 at net.pms.PMS.createInstance(PMS.java:1018)
02-06 20:07:47 at net.pms.PMS.main(PMS.java:1114)
Ranger187
Contact:
Post by Ranger187 »
Improved Vizio... Oh boy. We are making progress. Doing more testing on my Vizio tonight!
AlexanderGson
Post by AlexanderGson »
awschmidt wrote:thanks for the new release, but UMS 3.4.0 can't work with movieinfo anymore.
Error:
I got that as well. Had to remove movieinfo from plugins or else UMS would not detect my PS3.
Wolfgan wrote:Thx for the release. Will install and test it! I noticed that tsMuxer lately updated to v2.6.12 but UMS seems distributing v2.2.3, w/o including some improvements and fixes in between (http://www.digital-digest.com/software/ ... ry.html#61). Any reason for that?
Thanks again, Wolf
Because of a bug in the newer tsMuxeR versions which causes it to not work with some videos :)
Error:
I'll look into it, thanks for reporting it
Madoka
Post by Madoka »
Thanks for the new release. I feel bad for SB54. It never got included in an official release.
Madoka wrote:Thanks for the new release. I feel bad for SB54. It never got included in an official release.
Poor SB54, sorry my friend! You still made 364 people happy! I always look forward to your replies on our announcement threads, Madoka! :)
pipin
Post by pipin »
Great work. Got a new 32" Samsung and UMS works on this one without problems.
Regards,
Jens
Fiddl3
Post by Fiddl3 »
after update I'm getting error on every file.
I have to downgrade to 3.3.0 version witch work perfectly
Example:
02-07 23:18:25  Error adding child: "Banshee#######################################.mkv"
	at net.pms.dlna.DLNAMediaInfo.parse(DLNAMediaInfo.java:718) ~[ums.jar:3.4.0]
	at net.pms.dlna.DLNAMediaInfo.generateThumbnail(DLNAMediaInfo.java:379) ~[ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.checkThumbnail(DLNAResource.java:2521) [ums.jar:3.4.0]
	at net.pms.dlna.RealFile.checkThumbnail(RealFile.java:289) ~[ums.jar:3.4.0]
	at net.pms.dlna.RealFile.isValid(RealFile.java:86) ~[ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:504) [ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:480) [ums.jar:3.4.0]
	at net.pms.dlna.MapFile.manageFile(MapFile.java:116) [ums.jar:3.4.0]
	at net.pms.dlna.MapFile.analyzeChildren(MapFile.java:169) [ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.discoverWithRenderer(DLNAResource.java:974) [ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.getDLNAResources(DLNAResource.java:892) [ums.jar:3.4.0]
	at net.pms.network.RequestV2.answer(RequestV2.java:654) [ums.jar:3.4.0]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:295) [ums.jar:3.4.0]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:253) [ums.jar:3.4.0]
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [ums.jar:3.4.0]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [ums.jar:3.4.0]
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:3.4.0]
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [ums.jar:3.4.0]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_45]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_45]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_45]
02-07 23:26:09  Error adding child: "Iron Man 3###################################################.mp4"
