Add support for Cambridge Audio Evo streamer amps.
I have been using UMS on my PC for a while now, and it works well!
I have recommended it to many people, including those on the Cambridge Audio Evo users group.
The Evo 75 and Evo 150 streamers have become popular and recognized as "best of breed" all-in-one streamers, so I reckon it's time you supported these units "out of the box", so to speak.
I have modified my local UMS version to display the Evo that is on my network, but each time you release a new code version, I have to add my "CA-Evo 75.conf" file into the "renderers" folder, and modify the UMS.jar file to add the image file of the Evo into "resources\images\clients". It looks pretty on UMS, but I can't use UMS to control what is playing or volume (by clicking on the Evo image).....
It's OK me having to do this, but lots of users would be worried by this, so can I help in some way to get Evo's supported as standard?
Note the the Evo 75 and Evo 150 look identical and as far as DLNA is concerned, behave the same, except reporting being a 75 or a 150...
I attach the files I am using with UMS 13.8....
- Cambridge_Audio_Evo_75-small.png (33.07 KiB) Viewed 37854 times
CA-Evo 75.conf
- (1.57 KiB) Downloaded 10048 times
Re: Add support for Cambridge Audio Evo streamer amps.
You could open a pull request on Github to have your conf and image included.
Thanks - but I haven't made any changes in the repository; it's all local to my PC.
I don't know how to use github - I was hoping someone familiar might add Evo support
... As I say, at present, it's only about showing a picture of an Evo 75 or 150, I cannot send music to the unit or control volume, bump tracks/stop/start etc.
