No UMS Source on Samsung Q60R
thraipse
Post by thraipse »
Hello.
UMS no longer appears as a Source on my Samsung Q60R (model QN65Q60RAFXZA) TV after I updated UMS to v14.2.0. Prior to that update, I could access UMS and stream its contents without issue. I've restarted UMS a bazillion times with all Samsung renders enabled and reset the TV o factory (the firmware hasn't changed; no settings exist to enable/disable DNLA). Still nothing.
And that is pretty much the extent of my t'shooting of server and player devices.
What else should I attempt?
Re: No UMS Source on Samsung Q60R
It is probably something on your computer blocking it like the firewall or antivirus. I will need to see logs to be sure though, see the link in my sig.
