GitHub attachments
ExSport
Re: GitHub attachments
Post by ExSport »
DebugUMS_144822e_[25.2.2015].zip
(698.01 KiB) Downloaded 2633 times
ExSport
Post by ExSport »
"Visibility Debug" version...without LG TV which was OFF at time of debugging :?
debug_Yamaha_1bbfc78_Trace.zip
(32.43 KiB) Downloaded 2631 times
ExSport
Post by ExSport »
"Visibility Debug" version...LG TV ON
LG_debugnew.zip
(606.98 KiB) Downloaded 2607 times
JSLavigne
Post by JSLavigne »
Samsung-BDH5100.conf
(2.58 KiB) Downloaded 2631 times
debug.log
(51.99 KiB) Downloaded 2688 times
leroy
Post by leroy »
MediaInfo text output for examples of u263 and s263 fourcc.
examples.zip
(1.32 KiB) Downloaded 2950 times
ExSport
Post by ExSport »
Visibility debug - build e432b3eb3:
Four different detections of one renderer (LG TV with IP 192.168.1.18)
Build_e432b3eb3.zip
logs and screenshots
(291.94 KiB) Downloaded 2547 times
ExSport
Post by ExSport »
visibility debug build_e305fe0f0 : Two logs with exception, one without it, all have problems with "stuck/hung" javaw.exe process.
build_e305fe0f0.zip
(61.95 KiB) Downloaded 2637 times
ExSport
Post by ExSport »
Visibility debug Build_4083735d3: Two logs, one without and one with exception, all have problems with "stuck/hung" javaw.exe process.
Build_4083735d3.zip
(38.75 KiB) Downloaded 2748 times
infidel
Post by infidel »
This is a temporary patch to test renderer visibility issues. Put the enclosed update.jar next to ums.jar in your UMS program folder, and remove it after testing.
update-ums-5.1.0-renderer-name-fix.zip
for UMS 5.1.0 only - remove after testing
(76 KiB) Downloaded 2883 times
leroy
Post by leroy »
debug log for the issue: Audio MIME types stated in the renderer config file are no longer used
This is with with UMS version 5.1.0
debug.zip
(14.63 KiB) Downloaded 2819 times
For comparison debug log with v5.0.1
debug v5.0.1.zip
(15.97 KiB) Downloaded 2849 times
