Error streaming web
jps92
Error streaming web
Post by jps92 »
Since I've been using version 14.12 streaming no longer works in Firefox under Linux.
I have this in the traces file : 19:32:04 ERROR External input stream instance is null... stopping process
Re: Error streaming web
Could you post your logs so I can see?
jps92
Post by jps92 »
Voila
ums_dbg_2025-04-29-09-44.zip
(33.71 KiB) Downloaded 13150 times
I see it is failing as 'libx264' is an unknown encoder.
The reason for this is the wrong version of FFmpeg was used in the Linux release for 14.12.0 where that option was not enabled when it was compiled.
This was reported here and fixed in 14.12.1
There is a test build still available there with the fixed version of FFmpeg
If you have a graphics card you could change to GPU encoding and that should work. Check the settings for FFmpeg transcoding
Screenshot 2025-04-29 044347.png (7.76 KiB) Viewed 30148 times
Screenshot 2025-04-29 044325.png (27.38 KiB) Viewed 30148 times
