Data not available (windows)
king69_666
Post by king69_666 »
I am now having this issue. I'm on 14.12.0. I don't see any special character errors but I do get the message "Your browse data was not received from the server" on any browser I connect with. It appears if I try and access a root folder from the web browser. Log attached.
ums_dbg_2025-05-25-22-55.zip
(80.79 KiB) Downloaded 2097 times
Re: Data not available (windows)
There is a database error so nothing will be found
ERROR 2025-05-25 22:53:03.529 [main] net.pms.database.MediaDatabase Error checking tables: Scalar subquery contains more than one row; SQL statement:
UPDATE VIDEO_METADATA SET TVSERIESID = (SELECT TV_SERIES.ID FROM TV_SERIES WHERE TV_SERIES.TITLE = VIDEO_METADATA.MOVIEORSHOWNAME) [90053-232]
This will be the same as this.
You will need to delete the database so a new one can be made.
