Simultaneous install with PMS?
smirk
Post by smirk »
Hi, this may be a remedial question but I couldn't find it already answered anywhere.
I have PMS installed but I'd like to check out UMS. Can I have both installed at the same time? Any gotchas to be aware of?
Thanks!
smirk
Re: Simultaneous install with PMS?
Post by smirk »
Well, just to answer my own question...
UMS installs into its own directory and doesn't seem to interfere at all with PMS. Works great!
Sorry for the late reply, I was on holiday :) Yes you're right, they may interfere with eachother if they are run at the same time, but the installations will not interfere with eachother
