Muliple Error
Muliple Error
Sorry, it’s a translation, French > English, can you tell me where I can find the "conf" files, for:
Nokia Streaming Box 8010
Samsung Electronics UE40JU6000
Freebox SAS Freebox 6
Freebox SAS Freebox Media Server 1
Do the different errors come from this lack of drivers
Thanking you in advance.
Sincerely
Sincerely
- ums_dbg_2025-06-20-15-28.zip
- (415.7 KiB) Downloaded 2 times
Re: Muliple Error
I don't see any errors. What is the problem?
The only device I see that you listed is the Samsung TV and is using the right conf file.
I can't see anything else as they were not picked up by UMS when you made the logs.
There was no browsing or trying to play anything so I can't tell if anything is streamed or transcoded.
I can see some in the prev logs but as these are not in TRACE mode I can't see what conf UMS would use for them but there probably will be confs for them.
You do not need any drivers and should work on your DNLA supported devices even without a conf, just videos will not play if they are not supported on that device.
I do see you have blocked several IPs on your network.
One may be your router (I'm guessing 192.168.1.254) which would stop UMS from being able to send any data.
Try unblocking these first and see if it starts working.
Re: Muliple Error
Thank you for your response, I will test this solution during the day and get back to you.
A+
A+
