Exception in thread "jupnp-sync-protocol 500-1"
evinrude
Post by evinrude »
is this something that needs further documenting or is it something I can address ?
PI4b , ubuntu server , 24.04.2
025-06-25T17:26:30.404567-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.402 [jupnp-multicast-receiver 3-1] IP Filter: Access allowed to ADevice.evinrude.net
2025-06-25T17:26:30.411212-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.410 [jupnp-sync-protocol 500-1] Exception in thread "jupnp-sync-protocol 500-1" java.lang.RuntimeException: Method not supported: HEAD
2025-06-25T17:26:30.413178-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.412 [jupnp-sync-protocol 500-1] #011at net.pms.network.mediaserver.jupnp.transport.impl.JakartaServletUpnpStream.readRequestMessage(JakartaServletUpnpStream.java:117)
2025-06-25T17:26:30.413499-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.413 [jupnp-sync-protocol 500-1] #011at net.pms.network.mediaserver.jupnp.transport.impl.JakartaServletUpnpStream.run(JakartaServletUpnpStream.java:61)
2025-06-25T17:26:30.414221-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.413 [jupnp-sync-protocol 500-1] #011at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
2025-06-25T17:26:30.414741-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.414 [jupnp-sync-protocol 500-1] #011at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
2025-06-25T17:26:30.415231-04:00 ajmedia UMS.sh[19881]: INFO 21:26:30.414 [jupnp-sync-protocol 500-1] #011at java.base/java.lang.Thread.run(Thread.java:840)
2025-06-25T17:26:33.028040-04:00 ajmedia UMS.sh[19881]: INFO 21:26:33.026 [jupnp-sync-protocol 522-1] Finding user id: -1
boss
Re: Exception in thread "jupnp-sync-protocol 500-1"
Post by boss »
Is that using V14.12.0 or V14.12.1.
If so, there seems to be a problem for the Linux versions on V14.12.
See my thread here:
https://www.universalmediaserver.com/fo ... hp?t=16616
If the problem is in V14.12.0 or V14.12.1, try UMS V14.11.0 which works fine for me.
I will need to see your logs to see if it is a problem, see the red section above.
Like @boss says there appears to be an issue with 14.12 on Linux that may be the cause but need more information to find clues at what it may be.
