[Solved] Samsung F6200 doesn't show thumbnails
I'm new to UMS, so maybe this has already been answered. Excuse me if that is the case.
I have a Samsung F6200 TV and I can't manage to see my UMS served videos (so far I only have videos in my shared folders) with thumbnails or cover art. Is this a known issue, or is there some configuration I'm missing?
- SharkHunter
- Developer
Re: Samsung F6200 doesn't show thumbnails
Ok. Here go the logs. I've just started the server, set the log level to TRACE and, on the Tv, browsed through some of the shared folders. All I got was the default icons for "videos".
The files show, and they play perfectly.
BTW, I think this discussion I've found might be related: http://sourceforge.net/p/minidlna/discu ... /34276163/
- ums_dbg_NoThumbsSamsungF6200.zip
- (50.55 KiB) Downloaded 688 times
Any news on this issue? Can I help somehow on resolving it?
- SharkHunter
- Developer
The TV doesn't even request the thumbnails. Maybe try changing to false in the render conf...
ThumbnailAsResource=true
I still don't get any thumbnails. I'm uploading the logs, to see if they help.
- (61.7 KiB) Downloaded 777 times
- SharkHunter
- Developer
It looks (after looking at your link) that Samsung decided it was a good idea to start using JPEG_SM stuff instead of JPEG_TN. Don't know the difference but we'll update.
Ok, thanks.
I'm uploading the log again, because the last one was with ThumbnailAsResource=true. I had not read the text well... Anyway, the result is the same. No thumbs.
- (61.05 KiB) Downloaded 696 times
As of version 4.2.1 this issue is resolved.
Thanks for confirming
