UMS constantly hanging after a while
discutabel
Post by discutabel »
UMS is constantly hanging or stops working. Also detection of a renderer is difficult. I got a LG LM55620S television. I see that when UMS is hanging Java is using up 600MB of memory. It has never worked with my television.
Just hanging, doing nothing.log
(290.31 KiB) Downloaded 572 times
SharkHunter
Re: UMS constantly hanging after a while
Post by SharkHunter »
You get this error
java.lang.OutOfMemoryError: Java heap space
indicating that your out of memory for the java process.
Try and increase the memory given to UMS. This is done during installation or by doing reg hacking. Or you can edit the UMS.bat and change 768M to something else and then start via the UMS.bat file.
discutabel
Thanks, that did help.
