[Solved] No subs on samsung UE40H5500AW
xochipilli
Post by xochipilli »
I've got no subs on my Samsung Smart tv, been looking around the forums and did not found any solution that works, I've tried renaming ffmpeg.exe as suggested, tried version 4.0.0-b1, java and k-lite codec up2date...
Is there anyone who found a solution for this yet? Any help is hugely appreciated!
Thanks.
xochipilli
Re: No subs on samsung UE40H5500AW
Here's the log file
Also tried UMS-3602b2b.exe posted on this thread, regarding no subtitles on the F series, also doesn"t work...
viewtopic.php?f=9&t=2046
(36.83 KiB) Downloaded 487 times
xochipilli
Logs from version UMS-3602b2b.exe (4.0.3)
ums_dbg_4.0.3.zip
(35.41 KiB) Downloaded 546 times
Thanks for the logs :) Does this version fix it? http://www.spirton.com/uploads/UMS/UMS-cc9f131.exe
xochipilli
Sadly, no subtitles either in UMS-cc9f131
What's the last version that worked? Old releases can be found at http://sourceforge.net/projects/unimedi ... s/Windows/
xochipilli
Well, I'm a new user and it's a new tv, none of the version I've tried worked until now, though sub's are working fine in mpc or on the tv when run from an usb stick.
Until now I've tried version 4.0.2/java7, 4.0.0-b1, 3.6.4 and 3.5.0 then i gave up...
If there might be an even older version that works, i'll be happy to try your suggestions...
Thanks for your efforts so far :)
xochipilli
Still no sub's...
Do you need logs, are they of any use in this case?
I should make a version with more logging actually to help narrow this down. I will if this one doesn't work: http://www.spirton.com/uploads/UMS/UMS-xochipilli-2.exe
