Can't play DVD ISO files on Samsung H series
xochipilli
Post by xochipilli »
I suppose I should be able to play DVD ISO files on my Samsung H series TV, UE40h5500aw, but I can't... do I need to configure something or is it a bug?
The ISO file is shown as a folder [DVD ISO]xxx.iso, when I enter that dir, a few titlexx files are shown, when trying to play I get the message "check network connection".
Same thing for dvd's in extracted form.
Suggestions? Thanks...
extractiso.zip
(47.82 KiB) Downloaded 404 times
iso.zip
(174.39 KiB) Downloaded 445 times
xochipilli
Re: Can't play DVD ISO files on Samsung H series
not working in 4.1.0 also
xochipilli
No? I looked through the forums, normally it should be supported, at least it is on some devices... Is it a bug, will it be supported on my device?
Any idea, anyone? Thanks...
