[Solved] ffmpeg.exe has a return code of 1073741819
pulp
Post by pulp »
.mkv files stop after 56 seconds or so. Does this Error Code 1073741819 have a simple Settings, fix? I have since transformed the file to .mp4 with Handbrake and it works flawlessly but would LOVE to NOT have to do this with all .mkv files. :D Thank you for any help! 8-)
Universal Media Server\win32\ffmpeg.exe has a return code of -1073741819! Maybe an error occurred... check the log file
DEBUG 2014-12-02 12:32:47.434 [ffmpeg.exe-5-Cleanup] Stopping process: ffmpeg.exe-5
(21.1 KiB) Downloaded 519 times
Playstation 3
WIN 7
i7 CPU 950 @ 3.07GHz 7.5 5.9
RAM 6.00 GB
AMD Radeon HD 5700 Series 7.3
UMS 4.2.2
Re: PS3: ffmpeg.exe has a return code of 1073741819! FIX?
Looks like an issue with the subtitles, you could try setting "defer to MEncoder for subtitles" in the FFmpeg settings
pulp
Post by pulp »
SubJunk wrote:Looks like an issue with the subtitles, you could try setting "defer to MEncoder for subtitles" in the FFmpeg settings
That WORKED!!! Thank you so much SubJunk. This should be a STICKY! :D
And scriptkiddies... don't forget to click on SAVE!
8-)
Re: [Solved] ffmpeg.exe has a return code of 1073741819
Great, thanks for confirming :)
