The data type is not supported. (800288C1)
Exorchist
Post by Exorchist »
Some of my files just plain refuses to be played.
I get the ever hilarious The data type is not supported. (800288C1). Trying to google that gives no relevant hits. What's even more "funny" is that I can't play the file without decoding at all. Works perfectly fine on my computer, and it used to work perfectly fine with PMS. There is no error message in Traces.
Type: Video
Codec: MPEG-4 Video (DX50)
Resolution: 432x240
Frame rate: 23.976000
Type: Audio
Codec: Windows Media Audio 2 (WMA2)
Channels: Stereo
Sample rate: 44100hz
Bits per sample: 16
Re: The data type is not supported. (800288C1)
Can you see if they work with 1.5.0?
Lacehim
Post by Lacehim »
Exorchist,
You could try telling UMS not to transcode that file type. I used this for my renderers for .mp4 & m4v extensions.
Also are you running on Windows, linux or Mac?
