Noob Question
fivecats
Noob Question
Post by fivecats »
Got the universal installed on windows 7. I can play back music from my Onkyo 535 ok. Is there any way to initiate media files from the pc instead of from the onkyo gui? The equivilent of wmv right click / sent to streaming command?
Thanks!
SharkHunter
Re: Noob Question
Post by SharkHunter »
In the new 5.0 this is possible over the web and/or UMS gui.
fivecats
Re: Noob Question
Post by fivecats »
SharkHunter wrote:In the new 5.0 this is possible over the web and/or UMS gui.
Thanks! Downloading it now : -)
fivecats
Re: Noob Question
Post by fivecats »
Ufff. This thing is kicking my butt. I got the Beta installed and found the web interface - very slick - but still have the same problem. That is, i can navigate and play the music that is stored on my PC via Universal / DLNA using the Onkyo remote contol & Onkyo window. But no matter what I do on the Web interface, i can't get the the music to stream to the Onkyo from there. Just plays locally on the PC.
The Onkyo shows with a nice shiny check mark in the Universal GUI.
I must be missing something really simple. Does anyone have any ideas? All suggestions welcome.
Thanks.
infidel
Re: Noob Question
Post by infidel »
fivecats wrote:no matter what I do on the Web interface, i can't get the the music to stream to the Onkyo
Have you tried this :)?
fivecats
Re: Noob Question
Post by fivecats »
Thanks. I had not seen that option. However this is what I get - and when i press the play button nothing happens : - (
See anything I am doing wrong?
infidel
Re: Noob Question
Post by infidel »
fivecats wrote:when i press the play button nothing happens : - (
Please attach TRACE logs showing a play attempt from the gui and then from the web interface (preferably using the same audio file).
fivecats
Re: Noob Question
Post by fivecats »
Thanks for your continued help. Log file attached showing 3 attempts on same file. 1) Web gui, bump, playbutton stopped after two seconds, counter stayed at zero, no sound from anwhere. 2) same result,only this time the playbutton froze grey. 3) played without bump, sound ok on local machine.
(37.5 KiB) Downloaded 591 times
infidel
Re: Noob Question
Post by infidel »
fivecats wrote:3) played without bump, sound ok on local machine.
I was hoping for "4. played from gui onkyo window, sound ok on onkyo" too for comparison :). The logs show the onkyo requesting audio data and ums sending it, so it's unclear why there's no playback.
fivecats
Re: Noob Question
Post by fivecats »
Well I went back and did that now. Played fine as always when cued from the Onkyo. I am pasting the log below - seems like maybe the problem is in the Onkyo? Looks like it was actually looping for 4 hrs after that last PC attempt earlier. But there was no sound from the Onkyo, even though its screen was set to DNLA / Universal. I am lost.
2-10 05:36:30 Started playing 02 Goddess.mp3 on your TX-NR535
12-10 05:36:38 Stopped playing 02 Goddess.mp3 on your TX-NR535
12-10 05:39:53 Started playing 02 Goddess.mp3 on your TX-NR535
12-10 05:46:59 Started playing 02 Goddess.mp3 on your Chrome
12-10 05:48:15 Stopped playing 02 Goddess.mp3 on your Chrome
12-10 09:31:34 Stopped playing 02 Goddess.mp3 on your TX-NR535
12-10 17:49:03 Started playing 02 Goddess.mp3 on your TX-NR535
12-10 17:51:17 Stopped playing 02 Goddess.mp3 on your TX-NR535
