M2TS Files not Completely Streaming to Samsung UE55HU6900
spida_singh
Post by spida_singh »
Hi
Just got myself a new TV, and found using the inbuilt DLNA client on the Samsung UE55HU6900 very good.
It works great with all files from UMS apart from M2TS files.
UMS 'sees' the files, but only sees M2TS files with a the size of 976.56KB, no matter how big it is.
Ive had them play a handful of times, most of the time the TV displays a 'network connection lost' error message
Any idea what maybe the issue?
Im using UMS 4.3.0, its the only version i had on since buying the TV.
Logs also attatched
Let me know if anything else is required.
ums_dbg.Samsung.UE55HU6900.zip
(113.44 KiB) Downloaded 565 times
spida_singh
Re: M2TS Files not Completely Streaming to Samsung UE55HU690
This is also the same with 4.3.1.
TV sees these files with a very small file size in KB, even though they are Gigabytes in size
Cheers
Optimus_prime
Post by Optimus_prime »
Do you know were i can get one of those files to test with? I have three Samsung TV's, PM me with the details if you can
spida_singh
PM Sent :)
Cheers
spida_singh
Re: M2TS Files not Completely Streaming to Samsung UE55HU6900
Did you test with the file sent?
Many Thanks
