Sony Bravia problem
Sony Bravia problem
I have tried several DLNA servers and UMS beats them all! My question is about iTunes. Sony BRAVIA televisions don't seem to know about the .m4a format. If I manually copy my iTunes music to another folder and rename all the files .mp3 they will play.
UMS adds a transcode directory to the original iTunes directory, and will play the first track correctly, then it dies. You can see this from the attached debug log (12-12 22:09:37). The identical files (renamed from .m4a to .mp3) in a different directory play perfectly (22:10:19).
It would be great if UMS could transcode the .m4a files so it one could play multiple tracks.
- (33.62 KiB) Downloaded 525 times
