[Solved] Do not work
jps92
Post by jps92 »
hi,
Since I passed to the version 5b I can read any more no files. And server is disconnected from the tv.
(31.31 KiB) Downloaded 493 times
jps92
Re: Do not work
Post by jps92 »
Correction: videos work well but they are shown in list [ffmpeg] { Audio:Ac3...} instead of their title.
jps92
Re: Do not work
Post by jps92 »
I forgot, the sound of .wav is strangely caused interference.
jps92
Re: Do not work
Post by jps92 »
Finally I solved the problem of the bad sound of certain files (.wav ), I added " TranscodeAudio = WAV " in Sony-BraviaEX.conf.
Re: Do not work
Thanks for letting us know, I've changed that around for the next version :)
jps92
Re: [Solved] Do not work
Post by jps92 »
Since the new versions of ums 4.4.0 and 5 "TranscodeAudio = WAV" do not work any more. I had to change for "TranscodeAudio = LPCM". It works in Linux not in windows (v5) !!
In ums 5, in windows, videos are shown in list [ffmpeg] { Audio:Ac3...} instead of their title.
