Denon 2112CI
counsil
Re: Denon 2112CI
Post by counsil »
My Denon 3808 needs flac transcoded, but my Denon 4311 doesn't. It's going to be hit or miss.
I agree to change the config like you did though.
Just my $.02 :)
Re: Denon 2112CI
So you have 3 Denons; 2112CI, 3838 and 4311?
Do the 3838 or 4311 have different user-agent values to the 2112CI? Maybe we can make different renderer profiles for them at least :)
P.S. did the change work for the 2112CI?
Shade
Re: Denon 2112CI
Post by Shade »
It worked. Is there anyway now to actually have it show up as a Denon receiver in the UMS program? My OCD is kicking in. Thanks for all your help.
Re: Denon 2112CI
Shade wrote:It worked. Is there anyway now to actually have it show up as a Denon receiver in the UMS program? My OCD is kicking in. Thanks for all your help.
SubJunk wrote:It has exactly the same user-agent value as Streamium, so it's impossible to tell which one it is.
This has nothing to do with UMS, it just isn't giving any unique info that any program could use.
Shade
Re: Denon 2112CI
Post by Shade »
SubJunk wrote:So you have 3 Denons; 2112CI, 3838 and 4311?
Nope just the one, that was the other guy :) Thanks again for the help getting it going.
