[Solved] Philips PUS7809 will not connect
Uppie
Post by Uppie »
my PUS7809 renderer will not connect to UMS. UMS "sees" the IP of the renderer, but UMS is not visible on the TV. Plex and Serviio register immediately and are visible on the TV. Sometimes (after a lot of rebooting of PC and renderer) UMS appears, but very unreliable. Looks a bit the same as viewtopic.php?f=5&t=2985
I've included logs (from 5.0.0b1, logs from 5.0.0. are the same) and the various XML-files the renderer gives when contacting through HTTP.
Thanx for the support and if you need testing, please let me know
Uppie
Uppie
Re: Philips PUS7809 will not connect
Post by Uppie »
Debugging UMS.rar
(26.07 KiB) Downloaded 1028 times
and the logs....
Hi Uppie, can you please let us know if it's the same with 5.0.0-a1?
Uppie
Post by Uppie »
Hi Subjunk,
did a clean install of 5.0.0a1. Basically same results (or lack of :D ). During the logging period i restarted UMS and also cold-started the TV once. I see some kind of recognition, but no "dialogue" between UMS en TV.
Logs are attached.
Thanx for the effort!
Uppie
ums_dbg_500a1.zip
(19.04 KiB) Downloaded 726 times
lubo
Post by lubo »
I have the same problem, my Philips is 42PFH6309. When install ver.4.4.0 everything work fine. But when install on Linux Server or Windows 8.1 host version 5.0 or 5.01 not see Universal Media Server in DLNA devices. I try with DLNA client form my Android device, and see Media server in network, and may play video files in android device. But my Smart Philips, do not see UMS in the same network.
infidel
Post by infidel »
Uppie wrote:I see some kind of recognition, but no "dialogue" between UMS en TV
And I see you're already on top of it with philips support :). It seems UMS found the PUS7809's split personality confusing:
DEBUG 16:42:23.133 [cling-11] MediaServer found: ... Descriptor: http:/192.168.2.2:49154/nmsDescription.xml
DEBUG 16:42:29.872 [New I/O worker #7] Device at /192.168.2.2 is a MediaRenderer: ... Descriptor: http://192.168.2.2:2870/dmr.xml
See if the patch below fixes it (and post logs either way please). Put the enclosed update.jar next to ums.jar in your UMS program folder, and remove it at the next UMS release:
[attachment removed] - try the patch below.
lubo
Post by lubo »
I try with this update, but not see UMS in my Philips DLNA browser. Attachment content debug.log before placing update, and after, also my UMS.conf. The second log is a device spy log invoking Get Protocol Info.
device_spy.txt
(6.07 KiB) Downloaded 687 times
debug5.0.1.rar
(20.99 KiB) Downloaded 638 times
infidel
Post by infidel »
lubo wrote:I try with this update, but not see UMS in my Philips DLNA browser. Attachment content debug.log before placing update, and after
Thx lubo, very helpful :). Try this patch (and please post TRACE logs either way):
update-ums-5.0.1-late-recognition2.zip
For ums 5.0.1 only - put update.jar next to ums.jar in your UMS program folder.
(51.76 KiB) Downloaded 1078 times
lubo
Post by lubo »
Thank you infidel for quick reply, now everything is fine.
1, See in main panel Philips TV;
2. See UMS in DLNA browser in my TV;
3. Play mkv file ( with subtitle);
In attachment is my trace log.
I hope that the next version will include the latest patch.
Thnak you
trace.rar
(2.17 KiB) Downloaded 656 times
infidel
Post by infidel »
lubo wrote:now everything is fine... in attachment is my trace log
Great, patch will be included in the next version :)!
This isn't actually a TRACE log. Could you please create one manually like so:
  • Shut down UMS.
  • Edit the file logback.xml in your UMS Program folder, changing <root level> from DEBUG to TRACE (near the end of the file), and save.
    	<root level="TRACE">
  • Start UMS, play something, and attach your debug.log, which will now include all TRACE messages.
