Weird issue with videos not appearing on PS3
Hey all. I ran into a problem today with UMS. For some reason two videos weren't showing in their respective folders on my PS3 while everything else does. When I open the folder, it just says there are no titles. The videos are in the codecs that don't even need to be transcoded (video: MP4/H.264 audio: AAC), so I'm not sure why this happens. Even weirder is that when I use PS3 Media Server, they show up and play without an issue. Anyone have an idea what may be wrong?
I use UMS 5.0.0 Java 8 for OS X. I used the last nightly and the issue still happens. Thought I'm not sure if the debug log will show anything I have included it.
- (9.21 KiB) Downloaded 374 times
Re: Weird issue with videos not appearing on PS3
Hi gumbyx84, thanks for the logs. However they need to be trace logs. Please follow the Problem Reporting Guidelines link up the top so we can help you
Sorry for late response. I thought the problem was solved by the last update (5.0.1) but no such luck. Here is the log files. Random but I'm also having problems skipping forward and backwards in videos. They are MP4 so I don't believe they are being transcoded.
- (25.87 KiB) Downloaded 400 times
