Simple MP2 Profile for Set-Top-Boxes
tomtom76
Post by tomtom76 »
Hello!
I am working for a Company and we make Installations of IPTV Boxes in Austria.
We need a good solution for a Media Server working with IPTV Boxes.
The Following Boxes are in Use:
TLA-5720SWFX/PVR (Manfuacturer ADB)
TLA-3801W (ADB)
No HD required.
The best solution would be a renderer profile to convert all to simple MPEG2 (Standard PAL) with Stereo Audio.
Is there a way to adress this with UniversalMediaServer?
I think a new profile should be enough?
Muppetman
Re: Simple MP2 Profile for Set-Top-Boxes
Post by Muppetman »
Should just require a profile assuming the IPTV box supports DLNA.
drcacho
Post by drcacho »
Do you have a technical sheet on what features and formats supports? It could be useful to determine whether it could work or not.
That kind of hardware tends to work only with a files o streams on a very strict format, it means you must use very specific options when you transcode files, because the hardware is too limited to handle certain files or streams.
On my work i create files to Motorola Set-top boxes, and in that particular case, we were unable to create that kind of files using open source tools, so the company purchase a carbon coder solution to continue with this project.
Good luck!
Hi tomtom76, yes it would be easy with a new profile. Something like this:
# Profile for ADB IPTV boxes
RendererName = ADB IPTV box
UserAgentSearch = YOURUSERAGENT
CustomFFmpegOptions = -target pal-dvd
CustomMencoderOptions = -ofps 25
tomtom76
Post by tomtom76 »
thank you for the answer.
it seems that my boxes have some problem with AC3 Audio.
is there a way to transcode all audio to MP3?
