UMS not seen permanently on Panasonic devices
Username
Post by Username »
I've two Panasonic devices on my network (a TX-P50VT50E TV and a DMP-BDT320 BluRay Player).
When I enter the DLNA menu on either device and then start up the UMS, I see it immediately, can access it, everything is working.
When I leave the DLNA menu and enter it again, I see the UMS for a split second in the server selection and then it is gone.
Or: when I start UMS and then enter the DLNA menu, I see the server for a split second and then it's gone.
In other words: the only way for me to access UMS is to be already in the DLNA menu and start the server.
Of course always starting/stopping the server is not an option :) but I'm wonder if anyone else has similar problems?
When I e.g. use my W7 PC as DLNA server, it works flawlessly on my TV/BluRay-Player.
UMS is running on headless on Debian Squeeze with jdk 1.7.0u9, mplayer is installed too.
Thanks for any help
Re: UMS not seen permanently on Panasonic devices
Hi Username, please post the debug.log after reproducing this
Username
Post by Username »
thanks for the reply. I just reproduced it. As seen from the log, two DLNA devices (is that the proper term?) were running on my network: the Panasonic TV and my W7 PC.
What I did to reproduce my problem:
  • Started TV, went into Media Server, saw my already running W7 PC
  • Started UMS, appeared after a few seconds on the DLNA server list on my TV
  • Left DLNA Server menu on my TV
  • Entered again: saw UMS for the split of seconds, then it disappeared. W7 PC was/is still present
  • Hit CTRL-c to stop UMS (that was around 22:13:48.467 )
DEBUG 2012-11-18 22:13:18.856 [main] My PID is 25710
INFO  2012-11-18 22:13:18.860 [main] GUI environment not available
INFO  2012-11-18 22:13:18.862 [main] Switching to console mode
INFO  2012-11-18 22:13:18.910 [main] Starting Universal Media Server 2.0.0
INFO  2012-11-18 22:13:18.911 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2012-11-18 22:13:18.911 [main] http://www.universalmediaserver.com
INFO  2012-11-18 22:13:18.912 [main] Build: 9456e1544 (2012-10-31)
INFO  2012-11-18 22:13:18.912 [main] Java: 1.7.0_09-Oracle Corporation
INFO  2012-11-18 22:13:18.913 [main] OS: Linux 32-bit 2.6.32-5-vserver-686
INFO  2012-11-18 22:13:18.913 [main] Encoding: UTF-8
INFO  2012-11-18 22:13:18.914 [main] Memory: 682 MB
INFO  2012-11-18 22:13:18.914 [main] Working directory: /home/ums/ums-2.0.0
INFO  2012-11-18 22:13:18.939 [main] Temp directory: /tmp/universalmediaserver
INFO  2012-11-18 22:13:18.940 [main] Logging config file: /home/ums/ums-2.0.0/logback.headless.xml
INFO  2012-11-18 22:13:18.941 [main] debug.log: /home/ums/ums-2.0.0/debug.log
INFO  2012-11-18 22:13:18.942 [main]
INFO  2012-11-18 22:13:18.942 [main] Profile directory: /home/ums/ums-2.0.0
INFO  2012-11-18 22:13:18.943 [main] Profile path: /home/ums/ums-2.0.0/UMS.conf
INFO  2012-11-18 22:13:18.944 [main] Profile permissions: rw
INFO  2012-11-18 22:13:18.945 [main] Profile name: vserv02.home
WARN  2012-11-18 22:13:19.342 [main] Error loading libzen: Unable to load library 'zen': libzen.so: cannot open shared object file: No such file or directory
INFO  2012-11-18 22:13:19.343 [main] Loading MediaInfo library
INFO  2012-11-18 22:13:19.405 [main] Error loading MediaInfo library: Unable to load library 'mediainfo': libmediainfo.so: cannot open shared object file: No such file or directory
INFO  2012-11-18 22:13:19.405 [main] Make sure you have libmediainfo and libzen installed
INFO  2012-11-18 22:13:19.405 [main] The server will now use the less accurate FFmpeg parsing method
INFO  2012-11-18 22:13:19.425 [main] Loading renderer configurations from /home/ums/ums-2.0.0/renderers
INFO  2012-11-18 22:13:19.434 [main] Loading configuration file: YamahaRXV671.conf
INFO  2012-11-18 22:13:19.459 [main] Loading configuration file: iPad-iPhone.conf
INFO  2012-11-18 22:13:19.469 [main] Loading configuration file: Philips.conf
INFO  2012-11-18 22:13:19.479 [main] Loading configuration file: PopcornHour.conf
INFO  2012-11-18 22:13:19.486 [main] Loading configuration file: BraviaEX.conf
INFO  2012-11-18 22:13:19.502 [main] Loading configuration file: N900.conf
INFO  2012-11-18 22:13:19.511 [main] Loading configuration file: WMP.conf
INFO  2012-11-18 22:13:19.522 [main] Loading configuration file: FreeboxHD.conf
INFO  2012-11-18 22:13:19.530 [main] Loading configuration file: Showtime3.conf
INFO  2012-11-18 22:13:19.544 [main] Loading configuration file: PS3.conf
INFO  2012-11-18 22:13:19.570 [main] Loading configuration file: XBMC.conf
INFO  2012-11-18 22:13:19.577 [main] Loading configuration file: Bravia4500.conf
INFO  2012-11-18 22:13:19.587 [main] Loading configuration file: DLinkDSM510.conf
INFO  2012-11-18 22:13:19.596 [main] Loading configuration file: PhilipsPFL.conf
INFO  2012-11-18 22:13:19.618 [main] Loading configuration file: OPPOBDP93.conf
INFO  2012-11-18 22:13:19.625 [main] Loading configuration file: SMP-N100.conf
INFO  2012-11-18 22:13:19.637 [main] Loading configuration file: DirecTVHR.conf
INFO  2012-11-18 22:13:19.649 [main] Loading configuration file: AirPlayer.conf
INFO  2012-11-18 22:13:19.662 [main] Loading configuration file: SonyBraviaHX800.conf
INFO  2012-11-18 22:13:19.674 [main] Loading configuration file: LGST600.conf
INFO  2012-11-18 22:13:19.683 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2012-11-18 22:13:19.687 [main] Loading configuration file: WDTVLive.conf
INFO  2012-11-18 22:13:19.693 [main] Loading configuration file: SamsungAllShare.conf
INFO  2012-11-18 22:13:19.700 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2012-11-18 22:13:19.706 [main] Loading configuration file: Streamium.conf
INFO  2012-11-18 22:13:19.711 [main] Loading configuration file: XBOX360.conf
INFO  2012-11-18 22:13:19.717 [main] Loading configuration file: Panasonic.conf
INFO  2012-11-18 22:13:19.727 [main] Loading configuration file: Bravia5500.conf
INFO  2012-11-18 22:13:19.734 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2012-11-18 22:13:19.739 [main] Loading configuration file: OPPOBDP83.conf
INFO  2012-11-18 22:13:19.744 [main] Loading configuration file: SonyBluray.conf
INFO  2012-11-18 22:13:19.752 [main] Loading configuration file: Android.conf
INFO  2012-11-18 22:13:19.757 [main] Loading configuration file: Kuro.conf
INFO  2012-11-18 22:13:19.764 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2012-11-18 22:13:19.795 [main] Loading configuration file: Realtek.conf
INFO  2012-11-18 22:13:19.801 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-11-18 22:13:19.802 [main] launching: mplayer
INFO  2012-11-18 22:13:23.309 [main] Done!
INFO  2012-11-18 22:13:23.421 [main] Searching for plugins in /home/ums/ums-2.0.0/plugins
INFO  2012-11-18 22:13:23.440 [main] No plugins found
INFO  2012-11-18 22:13:23.511 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-11-18 22:13:23.547 [main] Registering transcoding engine: MEncoder
INFO  2012-11-18 22:13:23.552 [main] Registering transcoding engine: FFmpeg
INFO  2012-11-18 22:13:23.553 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-11-18 22:13:23.554 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2012-11-18 22:13:23.555 [main] Registering transcoding engine: MEncoder Web
INFO  2012-11-18 22:13:23.557 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-11-18 22:13:23.558 [main] Registering transcoding engine: MPlayer Web
INFO  2012-11-18 22:13:23.562 [main] Registering transcoding engine: tsMuxeR
INFO  2012-11-18 22:13:23.563 [main] Registering transcoding engine: Audio High Fidelity
INFO  2012-11-18 22:13:23.565 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-11-18 22:13:23.566 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-11-18 22:13:23.567 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-11-18 22:13:23.619 [main] Using address /192.168.1.30 found on network interface: name:eth0 (eth0)
INFO  2012-11-18 22:13:23.620 [main] Created socket: /192.168.1.30:5001
INFO  2012-11-18 22:13:23.945 [main] Checking shared folder: /data/shared/Fotos/
DEBUG 2012-11-18 22:13:24.233 [main] Sending ALIVE...
INFO  2012-11-18 22:13:24.240 [main] Using the following UUID configured in UMS.conf: 3952c4f8-c5b6-387d-9844-112bdc926712
INFO  2012-11-18 22:13:24.420 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.3
INFO  2012-11-18 22:13:24.463 [pool-4-thread-1] Checking IP: 192.168.1.3 for Panasonic
INFO  2012-11-18 22:13:24.469 [pool-4-thread-1] Renderer Panasonic found on this address: genuine.home (192.168.1.3)
DEBUG 2012-11-18 22:13:24.499 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.3
DEBUG 2012-11-18 22:13:24.552 [pool-4-thread-1] Unix process ID (ping): 25738
DEBUG 2012-11-18 22:13:26.501 [SpeedStats Failsafe] Stopping Unix process 25738: ping-0
INFO  2012-11-18 22:13:27.831 [New I/O server worker #1-3] No IP filter specified, access granted to /192.168.1.52
INFO  2012-11-18 22:13:27.840 [pool-4-thread-1] Checking IP: 192.168.1.52 for WMP
INFO  2012-11-18 22:13:27.842 [pool-4-thread-1] Renderer WMP found on this address: rage.home (192.168.1.52)
DEBUG 2012-11-18 22:13:27.843 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.52
DEBUG 2012-11-18 22:13:27.845 [pool-4-thread-1] Unix process ID (ping): 25744
INFO  2012-11-18 22:13:28.815 [main] The server should now appear on your renderer
DEBUG 2012-11-18 22:13:29.844 [SpeedStats Failsafe] Stopping Unix process 25744: ping-1
INFO  2012-11-18 22:13:29.846 [pool-4-thread-1] Address /192.168.1.52 has an estimated network speed of: 1024 Mb/s
DEBUG 2012-11-18 22:13:38.813 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-18 22:13:48.467 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted
INFO  2012-11-18 22:13:48.467 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-11-18 22:13:52.230 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO  2012-11-18 22:13:52.230 [PMS Listeners Stopper] Stopping server on host 192.168.1.30 and port 5001...
Username
Post by Username »
I've observed another thing: whenever I wait long enogh in my DLNA server browser menu on my TV, after some waiting the UMS pops ups; and coincidentally it matches the following message in the debug.log
DEBUG 2012-11-19 18:11:10.765 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 18:14:14.874 [UPNP-AliveMessageSender] Sending ALIVE...
Given the message I don't consider this a big surprise :-)
I left the DLNA server browser on my TV right after the event at 18:11:10 and entered it again. It popped up once UMS sent another ALIVE message. What I'm seeing makes absolute sense to me.
However, I don't understand why my TV would delist/remove UMS when I leave/reenter the menu.
Or: when UMS is already running, I turn on my TV and go to the DLNA server browser. After a few seconds my windows machine shows up. UMS starts to appear when it sense the ALIVE message.
I don't know the technial details about all this network stuff going on, but is possible that the TV sends out a broadcast to find all devices and only the windows machine responds (or is the only one receiving the broadcast)?
bartekpawlak
Post by bartekpawlak »
Hi, I have exactly the same problem. Have you found any solution for it?
Thanks in advance.
Bartek
Username
Post by Username »
No, I didn't/couldn't pursue it. App/config all is still there but unused. I still use my Windows machine as a DLNA server (means need to turn it on every time since it's my desktop machien).
