intresting error + comodo makes me want to punch things
ifurn0
Post by ifurn0 »
thanks for the help in advance and keep up the awesome work (id love to help but my java skillz just aint up to scratch yet)
also as a major feature request to be able to send a shutdown command from the play station for the whole file server? (not just ums) since its easy to send a magic packet wake up on lan on android :)
*edit, (forgot) win7 64bit, latest updates, latest version of ums, using a dozen soft direcrory symbolic links as well, latest version of comodo free.
*edit, main bug gone, turns out ums wasn't updated after all, as for comodo it asked for permission to alow ums and its working now i think
did a clean install it so once the computer stops chocking coughing spluttering and dying trying to rebuild the file list ill run some tests and tweak :)
*edit running like a dream, thanks :)
(20.94 KiB) Downloaded 419 times
