Video playing faster than audio (not typical sync problem)
Audioboxer
Post by Audioboxer »
Hi guys, coming over from the PS3MS boards.
I've attached a short part of a 720p encode of The Big Bang Theory (episode 1 of season 1, so no spoilers). For a reason I cannot understand the video does not play correctly, it seems to play in a weird speed (best way I can describe it). If I manually tell it to transcode it's fine, this is with remuxing. It also works perfectly on the PC.
Can anyone test the file and possibly help? Happens with all the episodes.
http://dl.dropbox.com/u/10631352/01x01% ... ot-001.mkv
Thanks a lot :)
Re: Video playing faster than audio (not typical sync proble
Hi Audioboxer, welcome to the forum :)
Is there an original name for the video file, or was it released like that? It seems that they did something weird when making the file that causes it to report 9000fps, meaning it is a bug with the files. I suggest getting a better release like The.Big.Bang.Theory.S01E01.720p.BluRay.x264-SiNNERS or The.Big.Bang.Theory.S01E01.720p.HDTV.x264-CTU and hopefully they will work fine :)
Audioboxer
SubJunk wrote:Hi Audioboxer, welcome to the forum :)
Hi, thanks! Great work with UMS/PS3MS by the way, been using for years now.
It's a personal rip it seems, available on the pirate tracker (don't want to link to keep forum from any trouble). Went with it to save some space, but I may just take your advice on a better release.
The.Big.Bang.Theory.Season.1-5.720p.BluRay.x264
General
Format : Matroska
Format version : Version 2
File size : ~300 MiB
Overall bit rate : ~2 000 Kbps
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 14:52:40
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20,0 / qcomp=0,60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1,40 / aq=1:1,00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 21mn 29s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
No easy way to fix? I used MKVToolnix to split the file.
ExSport
Post by ExSport »
What MediaInfo are you using?
Some older versions displayed wrong framarate (variable/constant) but I am almost sure tsMuxeR used for remuxing doesn't support variable bitrates.
I am not sure if MKVToolNix is able to change it to constant fps...
Audioboxer
ExSport wrote:What MediaInfo are you using?
I copy pasted that info from elsewhere, here is my output from the files
General
Unique ID : 269618585514348202586442773603878483551 (0xCAD6A696EE9F6BA253DA052EF040B65F)
Complete name : E:\The Big Bang Theory Season 1-5 Complete 720p\Season 1\01x01 - Pilot.mkv
Format : Matroska
File size : 323 MiB
Duration : 22mn 58s
Overall bit rate : 1 967 Kbps
Encoded date : UTC 2012-10-06 13:15:42
Video
Format : AVC
Duration : 22mn 58s
Height : 720 pixels
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=24,0 / qcomp=0,60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1,40 / aq=1:1,00
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 22mn 58s
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Language : English
Default : No
Forced : No
ExSport
Post by ExSport »
Will try to test your sample but better to post your debug.log if possible. Every restart of UMS log is rewritten so restart UMS, play affected file and send a log so correct data will be saved there.
Audioboxer
ExSport wrote:Will try to test your sample but better to post your debug.log if possible. Every restart of UMS log is rewritten so restart UMS, play affected file and send a log so correct data will be saved there.
Sorry been busy, I'll get on that tonight :)
