Version 2.2.2 is released
General:
You can download it from the front page. OS X build coming soon.
This release improves file support on many renderers, increases True Motion speed and improves design.
Changes since 2.2.1:
  • General:
    • Improved support of many files, especially on non-PS3 renderers
    • Fixed AVI support on Panasonic TVs
    • Cleaned up the "serving" text at the bottom of the program
    • Fixed conditional horizontal scrollbar
    • More accurately determine which formats tsMuxeR supports
  • External Components:
    • Updated InterFrame to 2.3.0, which:
      • Increased speed
      • Improved quality in high-action scenes
      • Optimised memory use
      • Supports more video cards
    • Updated MPlayer/MEncoder to SB47, which:
      • Disabled direct rendering for non-ref frames only again
      • Fixes a bug which detected transport streams as finished when they weren't
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
glebb for building UMS for OS X
ExSport for hours of testing and contributions to this version
Chyaddo
Re: Version 2.2.2 is released
Post by Chyaddo »
:D :D :D :D :D
SuperDre
Post by SuperDre »
Thanx, but I don't see the bug of showing external as embedded subtitles at the same time as being fixed, is it fixed? it's one of those bugs that prevent's me from using UMS (as a lot of my files have embedded subtitles but I also have external subtitles due to the embedded being a different language or just plain awfull).. (renderer PS3)
Madoka
Post by Madoka »
I've run across this too. Selecting from the Transcode Folder doesn't help either.
Maybe there could be an option like "Prefer external subtitles to embedded subtitles" where the internal subtitles would just be ignored if external subtitles were present.
Or a user defined list of order of perference by subtitle type, like
ass>ssa>srt>smi>idx/sub>internal.
Just wondering.
vulcan
Post by vulcan »
Hi
platform: Windows 8
language: russian
UMS:2.2.2
on screen: force networking interface not correct displayed
