Version 2.2.4 is released
General:
This release prevents subtitle overlaps and features many MEncoder improvements!
Changes since 2.2.3:
  • General:
    • Prevents internal and external subtitles from showing at the same time
  • External Components:
    • Updated MPlayer/MEncoder to SB48, which:
      • Runs faster
      • Crashes less
      • Detects framerates more accurately
      • Fixed subtitle bug on certain CPUs
      • Improved audio/video sync
      • Fixed memory leaks
      • Improves AVI support
      • Fixed audio stuttering/repeating bug
      • Fixed alpha for ASS subtitles
      • Improves permissions handling on Windows
      • Removes incorrectly categorised fonts
      • Makes ASS/SSA subtitle rendering up to 3.5x faster
      • Improves AC-3 audio buffering
      • Fixes a bug which detected transport streams as finished when they weren't
      • Improved MPEG-PS encoding
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X release
sHawTY
Re: Version 2.2.4 is released
Post by sHawTY »
Still waiting for the OS X version of 2.2.4.
Hope it will be released soon. =)
The OS X version is released now, thanks for waiting :)
sHawTY
Post by sHawTY »
SubJunk wrote:The OS X version is released now, thanks for waiting :)
Downloading now. Thank you. :-)
robod
Post by robod »
Thanks for all your work ^^
Greetings from Spain!
Phonism
Post by Phonism »
"Prevents internal and external subtitles from showing at the same time" - thanks, I had that problem a couple of times, but just removed the external ones :P
2.2.4 does feel faster in the transcoding, since my computer is getting old and struggle with keeping up on most 1080P content, but with 2.2.4, it blasted through 1080P!
Thanks, SubJunk :D
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
Cool, thanks for the feedback guys :)
keefor
Post by keefor »
Samsung for the win. i used to use a PS3 but it broke a year ago.
