Can't play video files only
ken.yong
Post by ken.yong »
I have configured UMS to play music files and photos OK on my Samsung TV. However, I am unable to play ANY video files (tried different file extensions still unsuccessful). I can browse and see the thumbnails, just can't play them. [Plex and Serviio play videos well on TV if it is relevant]
Since I can play music files and photos OK, it leads me to believe UMS can communicate with my TV well. I am just not sure why I can't play videos.
Any help is appreciated!
kuroukage
Re: Can't play video files only
Post by kuroukage »
What model is your TV and which renderer is UMS using for it?
ken.yong
Post by ken.yong »
It's Samsung UN55EH6070.
Renderer is XBMC on desktop and Samsung AllShare on TV.
I did see the followings in my log:
"Process C:\Program Files\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occurred... check the log file"
and
Buffer read ArrayIndexOutOfBoundsException error:
02-16 19:25:46 readCount: "99999750000"
02-16 19:25:46 maxMemorySize: "209715200"
jackychen159
Post by jackychen159 »
I have same problem.
My samsung TV can't play any transcoded video.
I add two line in the bottom of SamsungAllShare.conf to disable transcode
MediaInfo = true
Supported = f:.+
or just add video's extension after
StreamExtensions=mkv,mp3,mp4,avi,mov
now, my TV can play FLV MPE and RMVB, but still can't play MPEG-1 or WMV
btw, ps3mediaserver have similar problem and i didn't find solution in their forum.
valib
Post by valib »
Can you provide debug.log see topic "How to ask for support" to help us identify your problem?
tubby
Post by tubby »
I am experiencing the same issues as ken.yong with my Samsung AllShare. ArrayIndexOutOfBounds excpetion. I also get this on my Android Device.
I am trying different transcoding engines and the problem differs between them. I'll try to collect a recent debug log when using my Samsung renderer .
kuroukage
Post by kuroukage »
Please see this topic as Valib suggests and post your debug.log files.
tubby
Post by tubby »
kuroukage wrote:Please see this topic as Valib suggests and post your debug.log files.
Will do :-), I attached a debug package covering (trace enabled) when I am trying to transcode a DVD ISO. I'm getting ArrayIndexOutOfBoundsException. I assume it is part of the buffering process, when looking at the code.
When running the mencoder command directly on the computer running UMS on the command line and then reading it via mplayer or vlc it works, so something is not working as expected.
Avi files are working however but any transcoding seems to fail. I am running kubuntu 12.04 LTS and I have tried both IcedTea and Oracle java 7 versions.
ums_dbg_samsung.zip
(44.91 KiB) Downloaded 757 times
tubby
Post by tubby »
I finally got transcoding of DVD:s to work on my Samsung TV. I tried different settings on Mencoder and I tried debugging the code of UMS but no light was shed on my problem.
The thing that was missing was in the SamsungAllShare.conf and the following line.
ChunkedTransfer=true
