UMS refuses to initialize when updating to version 6 and above
Hello!
So I've been previously running UMS 5.3.1 and it ran fine. Today I noticed there had been quite a few updates up until version 6.2.0 which I installed by uninstalling the old version, ticking the fresh install box on the installer and... it doesn't work. Every time I try to intialize the application, I get this line in the log:
14:31:43 ERROR A serious error occurred during Universal Media Server initialization: Address already in use: bind
Which suggests that something is using the same IP? I guess? I tried running netstat but it shows nothing running on that port (which I assume to be 5001, since that's what it says in the settings). I've tried rebooting, killing the process, reinstalling and nothing works. The only version that will work is UMS version 5.3.1 and below which I'm running again. I also cannot change any settings at all in UMS 6 and above since... something...? refuses to initialize.
I attached the log I managed to pull from the application, I'm not sure if you need anything else to look up on the problem. Please ask if you do.
- (17.64 KiB) Downloaded 990 times
Re: UMS refuses to initialize when updating to version 6 and above
Sometimes you might have to launch Task Manager, and kill any Java.exe processes first, then run the installer.
Universal Media Server Wiki!
- Supermanfan77
Do you have antivirus software that has a realtime virus scan? If so add UMS's programs folder to the ignore list. I had this same issue and also where UMS would take upwards of 30 minutes to load while also taxing my CPU heavily. After I added UMS to the realtime virus scanner's ignore list UMS loads instantly.Eruanno wrote:Hello!
