[SOLVED] How to find which commit broken things ?
Sami32
Post by Sami32 »
Hello, i need help from the skilled ones !
I want to find which commit broken CoverArt(ID3 Tag) parsing between UMS 6.0.1 and 6.1.0
How can i do that ?
Thanks in advance for the helpful souls ;-)
Re: How to find which commit broken things ?
If you use Windows you can use UMSBuilder to build UMS, you can modify it to stop it automatically pulling the latest version, then pick which commit you want to build using TortoiseGit. That's pretty much how I do it
Sami32
Post by Sami32 »
Thanks for the tip, i didn't know about TortoiseGit, but i need the code source for UMS 6.0.1 ? i have only the executable, so where could i get the source ?
Or i need to take the actual source code and take off all the commits since 6.0.1 ? anyway i don't know how to do that...
How i need to proceed ?
EDIT : I just find now how to that on Github :) but i don't know yet how to modify it to stop it automatically pulling the latest version...
P.S. Could be possible to detect automatically the subjets beginning with http:// or have BUY and delete all these SPAMs ?!
In the UMSBuilder package, you can edit "Build for Windows.bat" and replace it with this:
@ECHO OFF
SET JAVA_HOME=%CD%\JDK-1.7.80
SET M2_HOME=%CD%\Maven-3.2.5
SET M2=%M2_HOME%\bin
Set PATH=%M2%;%JAVA_HOME%\bin;%PATH%
IF EXIST "%CD%\Code" GOTO MAVEN
:GIT_CLONE
CALL java -jar jgit-cli.jar clone https://github.com/UniversalMediaServer/UniversalMediaServer.git Code
GOTO MAVEN
:MAVEN
CD Code
CALL mvn external:install
rem CALL mvn clean
call mvn -P windows package
CD..
MOVE /Y code\target\UMS*-setup.exe "%CD%\UMS.exe"
rd /s/q "code\target\antrun"
rd /s/q "code\target\archive-tmp"
rd /s/q "code\target\classes"
rd /s/q "code\target\generated-sources"
rd /s/q "code\target\generated-test-sources"
rd /s/q "code\target\maven-archiver"
rd /s/q "code\target\surefire-reports"
rd /s/q "code\target\test-classes"
del /q "code\target\extra.nsh"
del /q "code\target\project.nsh"
del /q "code\target\UMS.exe"
del /q "code\target\ums.jar"
del /q "code\target\ums-*.jar"
pause
and that will make it build the code in the "Code" folder without updating it first. Then if you have TortoiseGit installed, you can right-click the Code folder, go to TortoiseGit in the context menu, then in the submenu click "Show log". Then you can scroll through that list and when you see the commit you want to build, right-click it in the list and click "Switch/checkout to this..." and click ok. Now you're at that commit. If you just want a specific version then instead of going to "Show log" you can go to "Switch/Checkout..." and click the "tag" option in that window, then select the version you want.
Sami32
Post by Sami32 »
Thank you very much :D i will try this today.
But i was trying to do it with Buildv2.bat, that far more difficult for me to understand, because i thinked that maybe it will be even more easy without the need to install again one more software ?
Do you know what i need to change in Buildv2.bat to make it working ?
:clone
	git clone https://github.com/UniversalMediaServer/UniversalMediaServer.git
	cd "%source%"
	git config --add remote.origin.fetch "+refs/pull/*/head:refs/remotes/origin/pr/*"
	cd ..
	exit /b
EDIT : Infidel script by the way ;)
viewtopic.php?f=25&t=1782&p=25627&hilit ... der#p27285
Cool, I don't have Buildv2.bat, I think Skeptical maintains that package
