Playback, just jumbs forward
when i start the film, its playing for a little bit, and then jumbs forward. makes no sense
- (25.31 KiB) Downloaded 428 times
Re: Playback, just jumbs forward
Setting the transcode buffer back to its default setting (200) should fix it
Thx! it did
But why is it behaving like this, if you increase the buffer?, shouldn't it be better?
Or what is the function of transcode buffer then ? :-/
Java limits the amount of memory we can use, and the bigger the buffer is, the more chance we have of reaching the limit, which is when this problem starts
