Problem with Resume function
Arathis1
Post by Arathis1 »
Hi
I have noticed a problem with the resume function. I am currently running UMS 6.5.2 and whenever I use the resume function one of two things happen either a) the file does not resume put begins at the start and on the info bar the file time shows 00:00/00:00. If I then attempt to fast-forward or re-wind the file crashes and the server skips to the next file.
Or B) the file resumes after where I stopped usually about 5 mins after and still shows 00:00/00:00 in the info bar and once again I cannot fast-forward or re-wind.
In Both scenarios even if I do not touch the control and let the file play, it always crashes after about 5-10 mins.
I have attached a log file where scenario A occurred and the file crashed when I attempted to fast-forward
Kind Regards
(78.67 KiB) Downloaded 491 times
