DTS keeps playing as AC3/DD
snackle
Post by snackle »
Hi and first off, thank you very much for the time and effort you have put into this wonderful application :)
I am having an issue where DTS audio tracks are being played as AC3, regardless of the settings I use on the transcoding page. I've set it to keep it in stream and am using an optical connection, but my receiver always shows it as Dolby Digital and will then, for some movies, trigger Cinavia error 3. Ive checked that the media files do actually contain a DTS stream with mediainfo. Any help would be much appreciated :ugeek:
Thanks in advance!
Re: DTS keeps playing as AC3/DD
Hi snackle, welcome to the forum! :)
Which renderer is this for?
snackle
Post by snackle »
Hey SubJunk, thanks for the quick reply.
I am using a Slim 320GB PS3.
