Windows app does not launch?
Fredo1650
Re: Windows app does not launch?
Post by Fredo1650 »
mik_s wrote: Sat Mar 15, 2025 11:12 am
Hello, After installing UMS, the application won't launch.
I noticed that the BIN and JRE17 files won't install. mik_s had raised this issue, and that's definitely the problem.
Version: UMS-Windows-14.10.1-x86_64.exe
Running the installer again will install the missing folders.
This issue has been fixed now for 14.11.0
@binary512 no problem. I am new to win11 on this new computer but I can't remember if I had to enable the tray icon or not.
Maybe it got turned off during an update? Win 10 on my old computer did not hide the tray icons.
Fredo1650
Post by Fredo1650 »
Thanks, mik_s, for the solution. It works correctly by running the installer a second time. The BIN and JRE17 files are present.
Thanks for the fix in the new version 14.11.0. :)
