PS4 Pro (PlayStation 4 Pro) renderer's configuration file
predator848
Re: PS4 Pro (PlayStation 4 Pro) renderer's configuration file
Post by predator848 »
Hi Sami32,
loool okaaaaayyyyy ;) Thanks
Unfortunately my usb isn't recognised by the ps4 pro even in fat32 or FAT so I'll try with an another usb key later.
I just want know something (noobiness: ON) is that normal that I have no picture when trying videos ? (noobiness: OFF)
Thanks a lot for your work again
Note: Please take your time ;)
(99.41 KiB) Downloaded 807 times
ums_dbg1.zip
2)
(97.13 KiB) Downloaded 791 times
ums_dbg2.zip
3)
(137.47 KiB) Downloaded 842 times
predator848
And the last one
ums_dbg3.zip
4)
(121.04 KiB) Downloaded 691 times
Sami32
Post by Sami32 »
The good new, is that an other user reported it as working, not using a PS4 or such a high video bitrate as your samples though.
I did make a more optimized version, that should give you suffisant speed to be able to stream it in real time, and changed the output specifications, as we are in the dark on what kind of MP4 the PS4 support until you test the 2 files on USB, HDD or DVD / BD whatever.
So, let's cross fingers ;)
https://we.tl/cvOn2b6kbT
Btw, i saw that you play them from the #--TRANSCODE--# folder. Could you play then normally, without going through that folder ?
EDIT:
http://www.playstationing.com/ps4/how-t ... layer/2227
https://community.playstation.com/conte ... -XomS.html
https://www.forbes.com/sites/kevinmurna ... 14259c2400
EDIT 2: Sorry, i've forgotten your question...
No thumbnail could come from the fact that the old FFmpeg version do not support well HEVC, though you should have the default thumbnail, or that the 4 seconds predefined, that you can change from the GUI, is on the black part of the video and you get only black as expected. In such case upgrading FFmpeg or changing the delay (10 s or more) could solve your thumbnails issue.
Anyway, if you still get thumbnails issue, you should open a new issue only for that, @Nadahar is the one "assigned" to this.
predator848
looool noooo. It's not about the thumbnail. The thumbnails are perfect but it's about the video. When I start playing the videos, my screen remains black with the "triangle, cross, square, circle" moving. And in the end: it tells me unreadable media.
For the usb unfortunately it doesn't work... snif, snif I have to buy a ps4 compatible usb stick.
predator848
I've tried the version you gave me. The only video who worked is jellyfish 55 mbps h264 in hd . Sniiiif
Note: Thanks for your work
(76.85 KiB) Downloaded 909 times
Sami32
Post by Sami32 »
Sorry, i've hard time to understand english :oops:
That's normal, as you streaming speed was insuffisant, so your TV was waiting and finally give error.
I did make NVIDIA optimization in this new build, i hope that you've a NVIDIA graphical card ?
EDIT: Yeah :D
So now let me check at your log, and see what we can optimize again.
I will post a new renderer later for an other test.
Sami32
Post by Sami32 »
Could you try the working video file with this renderer ? Thanks.
Sony-PlayStation4Pro.conf
(2.18 KiB) Downloaded 1006 times
EDIT: I just saw that my optimization was not taken correctly in consideration, so i will need to make a new build later.
predator848
Okay.
No, I have an AMD 7970m. Should i try the conf ?
Edit: Just to pricise that the jellyfish 55 mbps h264 is not a 4K video. its' a 1920x1080
Sami32
Post by Sami32 »
Yes, you can test this new renderer, as the purpose is only to know if the PS4 can support this kind of MP4.
Arrrgh...that while optimization failed, FFmpeg bugged. I will need to see what can be done for such GPU.
predator848
I've tried the worked video with the last conf and it works perfectly.
