Version 3.4.0 is released
Re: Version 3.4.0 is released
3.4.1 isn't released yet :)
Monica Jae
Post by Monica Jae »
Official release of 3.4.1 for Windows & Linux
latest commit 825a9eb7c6
SubJunk SubJunk authored an hour ago
contrib Formatting 10 months ago
src Revert "Renamed variables to make them more understandable" 14 hours ago
.gitattributes Keep Unix line endings on Windows in shell scripts 7 months ago
.gitignore Removed unused gitignore entry 3 months ago
CHANGELOG.txt Official release of 3.4.1 for OS X an hour ago <<<<<<<<<<<---------------
INSTALL.txt Updated file download locations 6 months ago
LICENSE.txt Moved from Google Code to GitHub 2 years ago
README.md Update README.md 2 months ago
README.txt Merge with master 3 months ago
UMS.launch Updated directory reference 10 months ago
pom.xml Fixed support for MovieInfo a day ago
bummer
what sucks more is that my last version was working pretty flawlessly. I was hoping i wasn't going to regret the upgrade, but there's a part of me that says to myself "yay an upgrade! what could POSSIBLY go wrong?"
well, up until that i was in my glory watching all the episodes of all the seasons of any show that i wanted for the past--well since 330 showed itself.
i've never had to but will look into this forum for legacy versions, because i want to go back til there is a fix for the fact that my Panasonic will not even acknowledge the fact that there is a server on the network. along with the annoying movieinfo plugin error everyone else is getting.
Monica Jae
AlexanderGson wrote:
awschmidt wrote:thanks for the new release, but UMS 3.4.0 can't work with movieinfo anymore.
Error:
02-06 20:07:47 Exception in thread "main" java.lang.NoSuchFieldError: EMPTY_BORDER
02-06 20:07:47 at net.pms.movieinfo.MovieInfo.config(MovieInfo.java:99)
02-06 20:07:47 at net.pms.newgui.PluginTab.appendPlugin(PluginTab.java:420)
02-06 20:07:47 at net.pms.newgui.PluginTab.addPlugins(PluginTab.java:413)
02-06 20:07:47 at net.pms.newgui.LooksFrame.serverReady(LooksFrame.java:568)
02-06 20:07:47 at net.pms.PMS.init(PMS.java:695)
02-06 20:07:47 at net.pms.PMS.createInstance(PMS.java:1018)
02-06 20:07:47 at net.pms.PMS.main(PMS.java:1114)
I got that as well. Had to remove movieinfo from plugins or else UMS would not detect my PS3.
How did you do that? In the conf?
My tv is detected, just not listing the server, hence, no fun :(
You can get older releases here
Monica Jae
emerson8 wrote:Small update;
Simply re-installing 3.3.0 again ontop of 3.4.0 and all is back to normal again.
and if one doesn't have 3.3.0?
Monica Jae
SubJunk wrote:You can get older releases here
thanks. i compiled .1 and will now throw 3.3.0 onto it. hope it works
disherabcd
Post by disherabcd »
Error:
How did you remove the plugin
I installed but do not see it under installed plugins.
gunnahafta
Post by gunnahafta »
When you say "Added support for 3D MKV files" what kind of support? Can it send a signal to turn on 3D mode to the tv? There is a flag you can set in a mkv file to do this so doesn UMS now see and send this flag? I know it is possible to automatically tell the TV to enable 3D because it does it whenever I put a 3D bluray into my PS3.
